03-11-2007, 5:46 PM
#1 (permalink)
Thanks: Gave 31, Got 3
HTPC cases that support ATX motherboards
I'm moving away from my P180 and want something that can sit nicely on my desktop, but can still handle the height of an X1900XT and so on. I won't be overclocking or anything, just want a really nice HTPC case for not too much (~£150).
I've been looking at the Zalman HD160 - looks fantastic and isn't too bad...just wondering if there are any others! Preferably a VFD / Matrix display on the front. The Zalman features 80mm fans and full ATX motherboard support, which is great as my motherboard is an ATX Asus P5W DH Deluxe.
Thanks!
K
03-11-2007, 6:31 PM
#2 (permalink)
Thanks: Gave 4, Got 906
Re: HTPC cases that support ATX motherboards
03-11-2007, 10:00 PM
#3 (permalink)
Thanks: Gave 15, Got 8
I went for one of te silverstone cases, grandia:
http://www.scan.co.uk/Products/Produ...oductID=518649
Not yet built the HTPC yet though, but nice looking case.
There are also some nice thermaltake cases out there.
05-11-2007, 9:48 AM
#4 (permalink)
Thanks: Gave 91, Got 332
Silverstone LS13 i think it is. I did however, have to take a dremel to it, when i fitted my Artic 64 cooler!
Sony STRDB930, Rotel RMB-1075, Arcam DV-89, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, 460gb TiVo, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
06-11-2007, 2:08 PM
#5 (permalink)
Thanks: Gave 6, Got 124
silverstone ssc lc-17b for ~£70
the best case for the money without a doubt. 6 3.5" bay's, 2 optical bays, 2x92mm fans at the front (not inc), 2x80's at the back (included). enough space to fit an 8800gtx ....it'll squeeze in just about anything you want to put in there except the big 120mm heatsinks that have the fan standing up - they are too tall. orb-type coolers fit perfectly well, as you can see.
i also have p5w in that case, although the board in the pic is an ip35-pro but that blew up on me lol
Sony VAIO fw-11s w/ 320gb WD Black hard drive
ONKYO TX-SR805, mission m71i's, panasonic th-50pz80b
ps3: cant remember atm 360 gamertag: JimmyDonWon
15-11-2007, 3:54 PM
#6 (permalink)
James what power supply would you rec for this case?? im thinking of putting together a HTPC based around one of the new 8800 gt cards and want to make sure i have enough "juice"
thx
15-11-2007, 4:34 PM
#7 (permalink)
Thanks: Gave 63, Got 233
Had a silverstone lc16m, now got a Zalman hd160. imo build quality is miles better on the Zalman.
Q321 32" LCD | Sony STRDA-1200ES | Sony 5.1 Spkrs & Sub | SKY+
Bluray HTPC | Slingbox Classic | Home Server | Popcorn Hour NMT A-100
[See HTPC Stickies here and here for advice on building a new HTPC]
