AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 02-11-2007, 3:08 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Power supply test
Regarding a problem I have posted in another section but would like a direct answer here if possible.
Question : If I just plug a psu in the mains should the fan be working ?
Thebadbandit is offline
Old 02-11-2007, 5:53 PM   #2 (permalink)
Thanks: Gave 0, Got 11
Re: Power supply test
if comp is switched on = working
if comp is switched off/standby = not working
IF mankinds carbon footprint is 3% of the worlds volcanoes.. its about insincere tax?
When forests are gone or oceans fall ill.. then we're in trouble.
Nu Breed is offline
Old 03-11-2007, 12:08 AM   #3 (permalink)
Thanks: Gave 63, Got 233
you can test it without a PC by shorting out a couple of wires
http://forums.vr-zone.com/showthread.php?t=130472
Q321 32" LCD | Sony STRDA-1200ES | Sony 5.1 Spkrs & Sub | SKY+
Bluray HTPC | Slingbox Classic | Home Server | Popcorn Hour NMT A-100
[See HTPC Stickies here and here for advice on building a new HTPC]
tinners is offline
Old 03-11-2007, 8:00 AM   #4 (permalink)
[quote=Thebadbandit;5764932]Regarding a problem I have posted in another section but would like a direct answer here if possible.
Can anyone just answer the above, IE I dont wont any other details.
Old 03-11-2007, 8:47 AM   #5 (permalink)
Thanks: Gave 11, Got 37
No
John7 is offline
Old 03-11-2007, 3:26 PM   #6 (permalink)
Thanks: Gave 1, Got 63
as above No
essjay is offline
Old 03-11-2007, 5:47 PM   #7 (permalink)
Thanks: Gave 2, Got 29
Some server PSUs will switch fan on (low speed) as soon as you plug into mains.
wywywywy is offline
Old 03-11-2007, 6:50 PM   #8 (permalink)
Thanks: Gave 3, Got 12
If you want no hassle and just want to see if your PSU is dead to rule out the mobo, then you can buy a PSU tester from maplin for £5. It plugs in and turns green if your PSU is working.
tonyk79 is offline
Old 05-11-2007, 9:51 AM   #9 (permalink)
mjn
Thanks: Gave 91, Got 332
Assuming there is nothing attached to any of the connectors, then no.
Sony STRDB930, Rotel RMB-1075, Arcam DV-89, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, 460gb TiVo, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
mjn is offline
Old 05-11-2007, 8:38 PM   #10 (permalink)
If you want to test your PSU without causing damage to your PC try the following
1. Disconnect the PSU from ALL components in the system.
2. Hook 1 or more cooling fans to the PSU to give it a load.
3. Get a small piece of wire, paper clip, or suitable object and short out pins 13 and 14 should be coloured balck and green and labled Blk Ground Green P.On (lo)
essjay is offline
power, supply, test
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
