31-10-2007, 11:37 AM
#1 (permalink)
Thanks: Gave 8, Got 21
HDMI mobo
I have a abit an-m2hd and just can't get anything better than stereo over the HDMI so far.
Is there a mobo that can pass on multi channel HD audio over hdmi?
i'm not bothered if it's amd or intel, matx or atx, as my current one can move to the plasma in the lounge. Hence i'll build another one for the cinema room
 help me
If three people tell you that you are drunk, you better lie down.
06-11-2007, 3:42 PM
#2 (permalink)
Thanks: Gave 18, Got 14
Re: HDMI mobo
Have a look at the ASRock range I'm sure theres one called 1333HDMI which has an HDMI output
Dave
Sagem HD-D56B, Sky HD, Sony PS3, Onkyo TX805, Toshiba SD900E, BK poweramps, Infocus SP7210, Grandview 80x45, Monolith double subwoofer, ProAc response 2.5
06-11-2007, 3:44 PM
#3 (permalink)
Re: HDMI mobo
I did find this one from gigabyte which i'm sure i read has hdmi 1.3. It so cheap that i'll buy it anyhow
Thanks anyway
10-11-2007, 10:38 PM
#4 (permalink)
Thanks: Gave 9, Got 15
Re: HDMI mobo
Embarker,
If you get this mobo could you let me know how it goes via PM this could be the board i am looking for also. I want something the does 1.3 also i wish they would just put the HDMI version on mobo's it would make life so much easier.
Panasonic TX32LXD700, Panasonic DMR EX-77, Onkyo 605, KEF 3005 5.1 Surround Speakers, HTPC (Blu-ray), Wii
18-11-2007, 3:28 AM
#5 (permalink)
Thanks: Gave 5, Got 70
Re: HDMI mobo
Guys,
There currently aren't any HDMI MoBo's that can do HD audio as bitstream via HDMI and both nVIDIA and ATi are still limited to 2-channel LPCM (48KHz). Intel G33/G35 can do multi-channel LPCM but I don't know of anyone that's tested it with PowerDVD yet to see if they allow it. It should work according to an expert on AVSForum but I'd like to hear from someone that's done it.
Cheers,
Wo0zy.
18-11-2007, 12:19 PM
#6 (permalink)
Thanks: Gave 4, Got 1
Re: HDMI mobo
Originally Posted by Wo0zy
Guys,
Cheers,
Wo0zy.
But do the Intel IGP's have any support for hardware HD video processing like Nvidia Purevideo HD ?
18-11-2007, 1:16 PM
#7 (permalink)
Re: HDMI mobo
If you mean HD acceleration then no. But nVIDIA integrated solutions don't either at present despite what the specs say. There are a lot of unhappy people complaining about this
Both solutions currently need a very good CPU for HD playback (especially AVC).
The nVIDIA options have better deinterlacing than current G33 options but G35 should address this. Of course this only matters if you're viewing interlaced content
Wo0zy
10-01-2008, 7:32 PM
#8 (permalink)
Re: HDMI mobo
Decided and jumped to the intel side with a quad core Q6600 and the intel board mentioned.
May sell/re-case the current htpc
He's to monday's re-build
10-01-2008, 8:39 PM
#9 (permalink)
Thanks: Gave 1, Got 61
Re: HDMI mobo
Asus P5e Vm Hdmi
10-01-2008, 8:42 PM
#10 (permalink)
Re: HDMI mobo
Yeap that's the one Asus P5E-VM HDMI Intel G35 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
17-01-2008, 9:12 AM
#11 (permalink)
Re: HDMI mobo
motherboard arrived cpu cooler and q6600 with 2gb of GeIl pc6400.
now have a single hmdi lead from htpc to amp and get dd and dts over it.
stereo is sent as multi channel though
Warning though, can't get bluray to play - says the gfx card is not hdcp !!!! -not that worried at the mo as assume this is a driver issue.
otherwise, it is very very quick, stable and quiet.
If anyone knows a solution to the multi-channel and hdcp please let me know.
19-01-2008, 4:52 PM
#12 (permalink)
Re: HDMI mobo
A couple of questions mate
1. I assume you're running Vista not XP? If XP you wont be able to playback BD or HD DVD. If Vista, which driver version do you have and what build of PowerDVD? The Driver/PDVD combo is very "fussy" with Intel IGP.
2. Are you saying you get Multi-channel PCM not Stereo for all sources? Any chance you can clarify this?
Wo0zy
19-01-2008, 7:56 PM
#13 (permalink)
Re: HDMI mobo
yeah it is vista, have version 3319a on powerdvd, have the latest video driver that vista gave me - struggling to find where you download/check with intel.
Decided to use anydvd hd to get around the hdcp handshake issue for the meantime, so at least can play hddvd/blu-ray.
My onkyo says dts/dd correctly, however just shows "multichannel" on everything else - seem to have lost any dd prologic/music etc.
I'll try some more films soon.
20-01-2008, 10:32 AM
#14 (permalink)
Re: HDMI mobo
tried another film this morning and "yes" do get the full 5.1 - gonna think about re-wiring room for 7.1 now as it sounded awesome - RIP DVD....................
Seems there is a known issue with intel and hdmi repeaters, which can give HDCP failure and when switching sources cause a drop to 800x600 res.
I have downloaded the latest intel g35 driver that was released this month but not installed yet.
On my to-do-list :-
get 24fps working if possible - i know from a mate's tivx that this does work with my mitsh LCD projector.
Load new intel driver if newer that the update version
Get some more blu-ray/hd dvd's to watch - he he
20-01-2008, 11:21 AM
#15 (permalink)
Re: HDMI mobo
Just read that the new driver from intel (here) fixes the HDCP issue so no need for anddvd hd - i'm off to play
p.s. Yes it works fine now
