AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 28-10-2007, 1:15 PM   #1 (permalink)
Thanks: Gave 0, Got 2
Intel E2180 or Athlon 64 X2 4800+
Looking to build a cheap gaming Pc for a friend and wanted to know the best CPU to get.
Mainly I am looking for stock power but maybe some mild overclocking later.
For the price range we are looking at (Under £70), the Intel E2180 and AMD Athlon 64 4800+ both look good buys.
It will be running with 2Gb 667 mhz Ram and an XFX 7600Gt XXX
What do you fine people recommend......?
Thanks in advance.
markeddy is offline
Old 28-10-2007, 1:34 PM   #2 (permalink)
Thanks: Gave 14, Got 46
Re: Intel E2180 or Athlon 64 X2 4800+
no contest mate. the 2180 is the better of the two. easily overclockable and runs faster stock compared to the AMD.
living room: optoma hd70, 106 in electric screen, samsung PS50Q97HDX, pioneer vsxd-915, wharfedale pacific pi-40, pi-20, pi-center, ms-309 sub, samsung 950, d-link RD320, sony PS3
bedroom: hitachi 42 PD5200H, denon 1905, pioneer 575A, x-box 360 + HD DVD
bagatanmd is offline
Old 28-10-2007, 2:58 PM   #3 (permalink)
Excellent, just the answer I was looking for.
And it is cheaper at Ebuyer :O)
markeddy is offline
Old 17-11-2007, 3:25 PM   #4 (permalink)
Another reason to bear in mind is that you can always upgrade to high end dual cores (or quads depending on chipset) on the 775 socket further down the line. Intel have a big edge at the moment, so I'd definitely lean that way.
Rennyboy is offline
Old 17-11-2007, 6:39 PM   #5 (permalink)
i agree! getting e2180 soon pair it with a p35 mobo, and away you go!
lukeh is offline
4800, athlon, e2180, intel
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
