I think I've purchased a wrong type of case for the HTPC.
Antec P182, having problems fitting it on racking/floor etc.
I couldn't find any HTPC cases with the height to fit a Scythe Ninja, MATX board with plenty of HD spacing (with silicon pads) and all case fans are in 12cm size. And I want plenty of room to work, not cramped inside.
The only case that comes close is the (I presume expensive) Silverstone CR-02 and even then front fan is two 92mm, not a single 120mm.
http://www.silverstonetek.com/produc...pno=cw02&area=
