I just upgraded to a 939 Dual Core Opteron 185 2.6 out of the box. Lots of people seam to have them overclocked to 3ghz but I cant seam to get anywhere near that. Ive never tried to overclock anything before which I suspect is the problem.
The best I can get is 2.836
Setting are 218x13 @ 1.45v
RAM 2.5, 3, 3, 7 218mhz * 2.85v
(ram is corsair 2-2-2-5 3200xl)
The standard volts for the processor is 1.3 to 1.35. Most people seam to have it overclocked to about 3ghz on 1.4v. If I try to go any higher Prime95 fails, "got 5 expected less than 4".
My northbridge fan is broken at the moment and a new one should arrive soon but my motherboard temps are fine. Could this be the problem?
Some CPUz images of the settings that worked before I upped it a bit a tightened up the memory.
