Originally Posted by dvdnoddy
Hi I've got a HTPC based on a ASUS M2A-VM HDMI motherboard.
Unfortunately it doesn't seem to support 1366 x 768 resolution through VGA (and whilst I appreciate this isn't a True PC resolution and I might only only be able to get 1360 x 768) the closest I can get at the moment is 1280 x 768.
I have tried the HDMI connection as well but that outputs 720p (1280 x 720).
Any idea's?
Haven't used this MBD, but your problem could be to do with the display you are connecting rather than the gfx card.
These days, gfx cards check the attached display's capabilities - the display answers this request by supplying the info programmed into it's EDID chip.
Sounds OK - but not when loads of display manufacturers appear to be incapable of programming the EDIDs in their displays correctly - TVs are the main culprits.
Try using Powerstrip - this will allow you to override the EDID data, and set any resolution you want - of course, the catch is that the display must actually support the resolution you are wanting to use. It's not unknown for LCD TVs, for instance, to be 1366x768 native, but then refuse to accept this resolution as an input in any way shape or form - it may be, for instance, 720p or 1080i at 50/60Hz only on the HDMI (maybe 1080p now as well), and 1024x768 at 60/72/75/85 on the VGA - no idea why some makers decided to do this (a penny pinching cost saving perhaps), but nevertheless, they've done it!
Which display are you connecting it to?
