AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 22-10-2007, 10:08 PM   #1 (permalink)
Thanks: Gave 1, Got 15
what bargain psu will fit a Antec p180 case
Need a psu for an antec p180 case i think i need longer cables as it sits at bottom of case.Its got to be under £60 600w and quiet if possible
thanks..
"Ive seen monkeys **** fights in the zoo more organized than this"!
martian1 is offline
Old 23-10-2007, 8:12 AM   #2 (permalink)
miceri's Avatar
Thanks: Gave 45, Got 62
Re: what bargain psu will fit a Antec p180 case
Cooler Master eXtreme Power 600W
20dB
£50 ish
Don't know about cable length for the P182, think you might need a modular supply so that you can replace existing cables with longer ones. But this will push the price up...
HiFi Primare I30, Primare CD31, Monitor Audio GS20, Enchantress XLR, MA Pureflow Silver, Grado SR80
Visuals Pioneer PDP-507XD, Pioneer DVR-520H, PS2
miceri is offline
Old 23-10-2007, 11:02 AM   #3 (permalink)
booyaka's Avatar
Thanks: Gave 60, Got 332
£3 over budget but probably the best rated one around
http://www.ebuyer.com/product/114945
if you need to extend to the top of the case get something like the following:
http://www.ebuyer.com/search/?strSea...olShowAll=true
dependant on which leads need extending.
Q6600 @ 3.37ghz (prime stable 8hrs) 4gb Ram, Gigabyte P35C-DS3R, Antec 900 and 8800GT (all watercooled!)
Nikon D40, 18-55mm and 70-300mm VR
booyaka is offline
Old 23-10-2007, 5:06 PM   #4 (permalink)
Thanks guys should have had a better title for thread like
Antec p180 owners what psu for £60 will fit without needing extenders.
martian1 is offline
Old 23-10-2007, 5:14 PM   #5 (permalink)
booyaka's Avatar
it's mostly dependant on your motherboard as to where it is positioned and also where the power connectors are in relation to the psu.
booyaka is offline
antec, bargain, case, fit, p180, psu
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
