AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 19-10-2007, 9:19 AM   #1 (permalink)
Thanks: Gave 1, Got 1
mb 1 slot
i got a new mb and i only has 1 IDE bit for my 2 hard drives and cd drive..
it is newer and more expensive than my last mb so i would have thought to get more than 1!
how can i can all 3 drives with this 1 slot?
u can only run 2 at a time thanks
rubez is offline
Old 19-10-2007, 10:03 AM   #2 (permalink)
Thanks: Gave 1, Got 14
Re: mb 1 slot
I had a similar problem with my ne Gigabyte mobo. In the end I spent £20 and got a new SATA DVD/RW solved all my problems ;->
HTH
marlowdrummer
Tosh 37WLT58, JVC 7012, Mordunt Short Front and Centre, Gale Atomic 8.2 Sub, Gale 3060 rears, Virgin V+ via HDMI, Wii, PS2, Atari Lynx and a Megadrive ;->
marlowdrummer is offline
Old 19-10-2007, 10:20 AM   #3 (permalink)
Re: mb 1 slot
so do i need to buy a new.. say about 500gig hard drive and move all my **** from the 120 and 80gigers over to the 500 and abandon the old drives?
whats a SATA?
rubez is offline
Old 19-10-2007, 10:22 AM   #4 (permalink)
mjn
Thanks: Gave 91, Got 332
Re: mb 1 slot
SATA replaced IDE. Soon, IDE will not even on any motherboards!
Sony STRDB930, Rotel RMB-1075, Arcam DV-89, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, 460gb TiVo, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
mjn is offline
Old 19-10-2007, 10:48 AM   #5 (permalink)
Re: mb 1 slot
do u need a new connector or a full on new drive?
hard drives are old fashioned now?
is it a new style of drive or something
rubez is offline
Old 19-10-2007, 10:52 AM   #6 (permalink)
mjn
Re: mb 1 slot
You can buy adaptors SATA <-> IDE, HDD's aren't old fashioned, but IDE is.
mjn is offline
Old 19-10-2007, 1:41 PM   #7 (permalink)
Thanks: Gave 0, Got 6
Re: mb 1 slot
Or if you really want to keep the old drives then you could just get a PCI IDE plug in card and run your CD/DVD drive(s) off this card.
TBH rather then waste good money on old I'd go out and get a decent SATA drive to replace the old IDEs. Your mobo should have come with a few SATA connection cables and maybe even a molex to SATA power convertor cable so make if you decide to go the SATA drive route that you have these or you'll need to order them with the drive.
IAmATeaf is offline
slot
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
