AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 18-10-2007, 1:15 PM   #1 (permalink)
Thanks: Gave 1, Got 4
Graphic card & CPU load question
My computer has a 820D CPU and a 7300LE card, would upgrading to a more powerful graphic card (say 2600pro) help to reduce the load on the CPU when playing DX9 games?
My understanding is that a more power graphic card would allow me to run games at better quality, but will not reduce load on the CPU
Got no response in the "Graphics Cards, TV Tuners, Webcams & Monitors" forum , so I thought I'll give this forum a try.
dcsy is offline
Old 18-10-2007, 1:56 PM   #2 (permalink)
Cool-hand's Avatar
Thanks: Gave 15, Got 49
Re: Graphic card & CPU load question
Hi dcsy
Sorry you had no luck in the other forum, sometimes it goes like that.. but members will help where they can, only computers are a kinda neche part of the forum Upgrading the graphics card should definitely help speeding things up and freeing up some cpu power.
Rgds
CH
Cool-hand is offline
Old 18-10-2007, 3:24 PM   #3 (permalink)
Thanks: Gave 63, Got 233
The CPU has little to do with graphics performance in games, so upgrading your graphics card is the way to go to get better gaming graphics but wont do anything to the CPU usage.
Q321 32" LCD | Sony STRDA-1200ES | Sony 5.1 Spkrs & Sub | SKY+
Bluray HTPC | Slingbox Classic | Home Server | Popcorn Hour NMT A-100
[See HTPC Stickies here and here for advice on building a new HTPC]
tinners is offline
Old 18-10-2007, 8:06 PM   #4 (permalink)
Thanks: Gave 3, Got 12
Not sure on your overall system spec, but maybe you would see a good performance increase from the video card you mentioned and an extra stick of Ram.
tonyk79 is offline
Old 20-10-2007, 3:58 PM   #5 (permalink)
Thanks to all who replied.
My machine has 1Gb. I doubt increasing this further will have too much effect on games.
I think I'll go ahead and get a better graphic card anyway. The 7300LE that I have is probably a bit weak for play games.
dcsy is offline
Old 20-10-2007, 4:02 PM   #6 (permalink)
mjn
Thanks: Gave 91, Got 332
You need something more powerful in the graphics department.
Sony STRDB930, Rotel RMB-1075, Arcam DV-89, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, 460gb TiVo, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
mjn is offline
card, cpu, graphic, load, question
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
