AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 17-10-2007, 1:00 PM   #1 (permalink)
Thanks: Gave 0, Got 8
PC Boot Problem - PSU issue ?
To get my PC to boot, I have to switch it on and wait for the drives to spin up, then press the reset button. If I simply switch it on, the boot process stops when the hard drives are being detected.
It's almost like there isn't enough juice to spin up the drives and boot the PC in one go.
Does this indicate that I need a more powerful PSU ? I can't remember off the top fo my head but I thinks it's 350W. I tried the PSU from another PC (also 350W) which didn't solve the problem.
For info, the PC has the following components :
Celeron D 3.06Ghz
3 HDDs (1 PATA, 2 SATA)
DVD drive
USB card reader
AGP (I think) graphics card - cheap, not powerful.
Yamaha DSP-AX757SE/Denon DVD-1910/Sanyo PLV-Z2/96" DIY Screen/Mission v62 fronts/Mission v6c centre/Mission v60 rears (2 pairs)/Modded Xbox/PS2/Server PC
paulw77 is offline
Old 17-10-2007, 7:44 PM   #2 (permalink)
Curly99's Avatar
Thanks: Gave 62, Got 383
Re: PC Boot Problem - PSU issue ?
yes it could mean the psu is on the way out, also as the HD takes a while to spin up it could be that one or all of those could be on the way out. see if you can borrow a psu off a mate to test before you buy a new one.
Curly
Please read the Forum Rules, When posting use the manufacturers full name and model number, it makes everyone's life easier
"All opinions expressed are my own and not representative of the AV Forums or any other related website."
Curly99 is offline
Old 17-10-2007, 8:26 PM   #3 (permalink)
The HDDs don't take a while to sping up, and they are all quite new.
As I said in the original post, I've tried another PSU (but also 350W)
paulw77 is offline
Old 17-10-2007, 11:53 PM   #4 (permalink)
Curly99's Avatar
ah, sorry quickly answered while I was modding the forums, does sound like the psu is struggling to give the pc enough power on startup try this psu power calculator here see if 350w is enough.
Curly
Curly99 is offline
Old 18-10-2007, 3:33 PM   #5 (permalink)
I think I've used that before. It only reckons I need 206W ! I'm at work and not 100% sure what the components are but I was close enough.
paulw77 is offline
Old 19-10-2007, 4:50 AM   #6 (permalink)
Curly99's Avatar
I would probably be inclined to get a good decent psu roughly around the 500 - 600W from one of the better manufactures, Hiper, tagan, enermax, seasonic...etc this way you know you have enough power even if you add more drives/componants it will be more efficient which is always good and should last for a few pc builds. other than that i don't know what else to suggest.
Curly
Curly99 is offline
Old 19-10-2007, 1:44 PM   #7 (permalink)
Thanks: Gave 0, Got 6
Which drive are you booting up off, are there any settings in the BIOS related to altering the spin up times?
IAmATeaf is offline
Old 19-10-2007, 9:33 PM   #8 (permalink)
I'm booting from the P-ATA IDE drive.
For info the three drives are :
160GB P-ATA
320GB SATA
500GB SATA
I'll check in the BIOS for drive settings.
paulw77 is offline
Old 20-10-2007, 6:15 AM   #9 (permalink)
Thanks: Gave 10, Got 7
Try it with just the boot HDD connected.
Philgo is offline
boot, issue, problem, psu
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
