10-07-2009, 12:29 AM
#1 (permalink)
| | New Member
Thanks: Gave 2, Got 0 | Comp and mainly mobo probs
Hello this is my first post  ...
But my problem is there is a a little box in the corner under my RAM and it shows a new number and i know what it is. So i looked in my 790i mobo manual and i found the number. 1C thats what it looks like. My manual says
CMOS Battery check: Test CMOS and check battery fail
i have no clue what that means..
does that mean buy a new nickle sized battery. and replace it? cause theres a normal battery in there that looks like a nickle.. This is a new gaming comp and im not very smart with comps yet.
i did build this..
I would like any solutions to this ASAP
thanks
Adam
10-07-2009, 2:05 PM
#2 (permalink)
| | Conspicuous Member
Thanks: Gave 302, Got 1,139 | Re: Comp and mainly mobo probs
Welcome
your right you need a new CMOS Battery , they are not dear  .. odd that the Battery has gone they last for years ..
Onkyo TXSR875B,BD30,XE1,Tannoy rC,Monolith-DF/Auralex GRAMMA
X38-DQ6,Intel Q6600 3.2 Ghz,4gb Ocz Reaper,GTX 280,Prelude xfi,1TB RE3,1TB Black,RE2 500GB,2X Raptors,Vista Ultimate/Win7,Enermax 1000 DXX, Alphacool LCD External,Stacker 830.
10-07-2009, 2:24 PM
#3 (permalink)
| | New Member
Thanks: Gave 2, Got 0 | Re: Comp and mainly mobo probs
thanks
where could i get a CMOS battery and how do i remove it?
also price,location of the battery in the mobo.
10-07-2009, 2:37 PM
#4 (permalink)
| | Conspicuous Member
Typical price Maxell Cmos Battery --- RS Computer Supplies ..
any good computer shop should have these or electrical suppler .. to take battery out that is dead easy and instructions to remove will be in motherboard manual .if not got that have a read at this http://www.computerhope.com/issues/ch000239.htm
also take the old one with you to shop and Double check ratings just in case ..
10-07-2009, 2:42 PM
#5 (permalink)
| | New Member
ok thanks good.
im mad that it died soo quickly? rather they should live for several years...But would a radio shack or best buy work for the stores? cause i have no clue where other electric stores are.
thanks |
10-07-2009, 2:55 PM
#6 (permalink)
| | Conspicuous Member
may just of been a faulty battery , never had one go myself only no of one that went a guy at work but his pc was over 10 years old, they should stock them or even Maplin .. good thing there only cheap you can get a Branded SuperDuper one now
10-07-2009, 2:57 PM
#7 (permalink)
| | New Member
thanks!11
10-07-2009, 3:00 PM
#8 (permalink)
| | Conspicuous Member
Thanks: Gave 302, Got 1,139 | Re: Comp and mainly mobo probs Quote:
