Connecting Laptop to AV
Old 09-03-2012, 2:41 PM   #1
zoltan666's Avatar
Thanks: Gave 8, Got 5
Hi guys, sorry in advance if this is the wrong place for this.
I need to connect my laptop to an AV point (red,yellow & white sockets). What is the best and easiest way to do this? My laptop has the normal VGA socket for a manitor but no S-video socket. I've searched on eBay and found these:
S-VGA to 3 RCA SVideo AV Composite Adapter Cable Laptop | eBay
S-VGA to S-Video Gold Plated 3 RCA AV Phone Composite Cable For HDTV PC Laptop | eBay
New High quality USB Male A to 3x RCA AV A/V TV Adapter Lead Cable 5Feet For PC | eBay
Would the usb one even transmit the picture??
Thanks so much in advance guys, i need this to work for my best man speech!!
Old 09-03-2012, 5:00 PM   #2
Thanks: Gave 264, Got 1,876
The first 2 links are never going to work as a VGA socket on a laptop will only output RGBHV video and not Composite video. VGA is also a video only connections so would require another cable for audio.
The 3rd link can't work either as USB is a digital only connection and Composite video plus stereo audio are analogue only connections. You need hardware conversion to go from USB.
Avoid all of these as they are a rip off and can never work.
To connect the VGA output on your laptop to a TV etc with only Composite video input will require hardware conversion with something like this - Proxima PC VGA to TV Composite Video RGB Converter: Amazon.co.uk: Electronics
Be aware though that the quality of the image will be fairly poor as Composite & S-Video are 720x576 which is almost certainly nowhere near the resolution from your laptop. Composite is also about the lowest quality connection going for video, with S-Video being only slightly better.
Mark.
