Go Back   AVForums.com > Computers > Computer Peripherals and Consumables > Monitors, Webcams and External Video Devices
Today's price checkPowered by
Samsung SyncMaster 2223NW Black
Acer X193HQb Black
Viewsonic VA2413WM Black
LG W2243S-PF Black
Acer X193HQb Black
LG W2243S-PF Black
HP 2009v Black
LG W2353V Black
Samsung SyncMaster P2270 Black
Dell UltraSharp 2209WA Black
Dell UltraSharp U2410 Black
LG W2043S-PF Black
 More...Prices updated February 9th at 3:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
24" monitor for Programmer / Gamer tobiwan Monitors, Webcams and External Video Devices 7 26-06-2009 8:08 AM
Old 26-06-2009, 1:17 PM   #1 (permalink)
multiple monitors
I run 4 monitors off my PC, using two Sli graphics cards. one of the cards is starting to fail - I had to replace one a while back and the remaining original card is now overheating due to the replacement being much more efficient.
Does anyone know whether there is a method of running multiple monitors (4)off a single card?
What is the beniefit, difference, advantage or otherwise of Sli over crossfire?
Can I use a SLi card with a crossfire card?
Dave
ntldave is offline   Reply With Quote
Old 26-06-2009, 4:36 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 32, Got 550
Re: multiple monitors
In my last job I used a PC (or 3) that had 8 monitors running off a single ATi card. I know ATi & Nvidia both do Quad GPU cards, as do Matrox and possibly others as well.
Just type 'quad gpu' into Google to see what comes up
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is online now   Reply With Quote
Old 29-06-2009, 3:05 PM   #3 (permalink)
Thanks: Gave 1, Got 338
That depends on whether you want to run them independantly or in clone made. Matrox do do a TripleHead2Go device that allows you to run a spanning three monitor desktop from a single connection, but only supports up to 1280x1024 for three monitors. If you've got two dual-link DVI ports then you could get a pair of DualHead2Go devices as they'll support four 1920x1200@60hz displays.
That's a far more expensive solution then just getting a second graphics card though.
They're pretty similar.
If you had four monitors running off two cards then the cards may have been SLI compatible but you weren't running SLI as SLI limits you to two monitors.
You can't SLI/Crossfire them together, but you can use them independantly in the same system. Well, provided you're not running Windows Vista as that's got an unfortunate limitation and won't let you use two different graphics drivers at once. Windows XP and Windows 7 will be fine, as will Linux if you can get the ATI drivers to work.
EndlessWaves is offline   Reply With Quote
Old 29-06-2009, 11:04 PM   #4 (permalink)
Thanks: Gave 5, Got 0
As far am I am aware the ATI 4850x2 would do what you are after - though it's really 2 4850 cards on a single PCI connector, so not sure if some of the problems mentioned above may still be present.
http://www.scan.co.uk/Products/1GB-S...-4x-DVI-I-HDTV
steviepunk is offline   Reply With Quote
monitors, multiple
Copyright © 2000-2010 M2N E. & O. E.
