| W960 - how to remove keypad?
Hi!
I have been having snags with the keypad on my W960i- the * key doesn't work. While I suppose that this is possibly the best key to lose the use of, but it's irritating nonetheless.
I have found a couple of replacement keypads and membranes for sale, but I am not sure what I will need to replace (if anything), as I can't get the keypad off the phone, after opening it up.
Does anyone know how to do this? I have had a prod from the front, but feel that I am likely to cause further damage this way. It's not clear at all how to remove from inside.
Charlie
