| Re: I'm due an Orange upgrade - what should I get??
Hi there,
I would personally recommend the Sony Ericsson C905, the camera is amazing and it has a host of features such as GPS and WiFi.
I too had a Nokia 6300, brilliant phones, slim and did the job (making/receiving calls) to a high level of satisfaction. However, as I just joined Orange, I got a Nokia 5800 Xpress but I dont really get on with touch screen, so I sold it and managed to get a new Sony C905 from a friend.
I wanted a decent camera with a Xenon flash, it amazes me how Nokia only have 2 (I can think of) phones with this, the N82 and the 6220 Classic.
I found on recent trips I had a pocket full of keys, cash, digi camera and phone, to reduce this by one is a positive step for me.
I am getting used to the nuances of aving a Sony again, but simply put the camera is amazing.
One thing I will say is debrand your phone when you get it. If its from Orange it will probably be full of crap when you get it, but use the Da Vinci client to derband, it costs about £9.50 and is well worth it.
The problem you have is generally more features means moor battery life. I simply switch off the 3G option on my handset so it only uses GSM and the battery life is fine.
Hope this has been of help.
