Originally Posted by cutiebbangel Just received the fone and Im finding it quite difficult to use!!
I know there are already 2 threads that are dedicated to the fone, but its a bit too long to catch up.
Here are a list of queries:
1. Is there any ways (apart from inputting it one by one)that i can quickly move my contacts onto my new fone
2. WHere can i download more themes?
3. How do i upload music?
4. How do i sync the fone to pc?
5. what can I do with the fone? some hidden features that i dunno of?!
many thanks |
When I get a new phone, I copy all the contacts to my sim card, put the sim in the new phone and then copy them from them sim, takes a few seconds.
There are no themes for the Omnia itself, but try looking at SPB mobile shell.
You need to use the USB cable, set the usb conection to 'mass storage' and it should appear as a hard drive on your PC. Or you can connect it using Activesync, if you use that you'll need to put your music in the 'my storage' folder.
You need activsync to syn with the PC.
I'm sure there's hundreds of features you're not aware of yet, and too many to list. Try looking at some of the Omnia forums or reading through those two threads.
