AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 30-05-2003, 10:16 PM   #1 (permalink)
erw
Thanks: Gave 1, Got 0
Angry opera, 02 and a 3650
Has anyone managed to get opera working on a 3650 connected to O2. I keep getting a can't connect to server problem....
erw is offline
Old 06-06-2003, 7:31 PM   #2 (permalink)
Gary D's Avatar
Thanks: Gave 206, Got 124
it get opera to work, fire up your wap connection, then when its connected start opera, and way you go.
gary
GT: Captain Splash
Kit List: a screen, some black boxes, some silver boxes, some cables, some speakers. Techno willy waving isn't my thing.
Gary D is offline
Old 06-06-2003, 9:45 PM   #3 (permalink)
erw
whats your server, opera needs GPRS the O2.WAP.GPRS doesn't work
erw is offline
Old 09-06-2003, 12:27 PM   #4 (permalink)
Gary D's Avatar
i'm using it on a P800 and my mate uses it on his 3650, i dont need GPRS to use it on mine (i'm on o2) and nore does he (hes on vodafone), check your wap settings are correct and you should be cool. if not ring o2 and explain the problem to them.
hope that helps.
Gary
GT: Captain Splash
Gary D is offline
3650, opera
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
