Originally Posted by baldrick Ok, if everything goes to plan I should be moving to the US for 2 years with work.
I'm currently 4 months into an iPhone contract and I'm wondering if anyone knows what the options are for freezing a contract etc... as I don't want to loose my current number? |
they might freeze it given your situation but given that the contracts available in 2 years when you return will most likely be far superior then you'd be paying a lot for a much reduced contract.
seeing as you're moving with work, you should ask them to pay it off (after all, you can't help moving) then do the suggested advice above to get the number on PAYG so you can keep it.
