AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 24-06-2008, 6:16 PM   #1 (permalink)
kingdannyb's Avatar
Thanks: Gave 4, Got 0
I'm using the w890 as an HSDPA modem but . . .
. . . it doesn't work at HSDPA speed !
I can connect on web'n'walk to the internet using the phone as a modem but at a maximum of 921.6 Kbps which is the maximum that windows XP will allow my pc to connect using a modem.
Seeing as the phone is receiving HSDPA at upto 3.2 Mbps and the USB connection can run at upto 480 Mbps how can I set the pc to accept the modem at a higher speed ?
kingdannyb is offline
Old 25-06-2008, 7:01 PM   #2 (permalink)
Thanks: Gave 6, Got 73
Re: I'm using the w890 as an HSDPA modem but . . .
Are you on a wnw plus or max plan ?
Sony KDF-E50A12U, Xbox 360 x3 Phillips DVDR80 (DVD Recorder), Pioneer VSX-515-S 7.1 Reciever, Kef Q9 Centre, Kef Q3 Fronts, Kef Q1 Surrounds, MJ Accoustics Reference 100 Sub, Chocolate Labrador - Scooby Doo mk1
Sy1441 is offline
Old 25-06-2008, 7:40 PM   #3 (permalink)
Thanks: Gave 26, Got 227
it's got nothing to do with the wnw plan..
it's all to do with windows artificial limits on analog modems.
back in't good ol' days when everyone used 33.6 or 56k modems, there was no real point in allowing faster modem connection. (what would utilise the speed??)
921.6Kbps is the highest speed that windows will allow through a daft old school modem connection
If you find an answer, I'd like to know too
insomniak123 is offline
Old 26-06-2008, 2:58 PM   #4 (permalink)
kingdannyb's Avatar
I'm on Web'n'Walk plus but that's not the issue.
As above, it's a pc set-up problem to do with modem speeds.
I need a way to connect the phone to the pc but not as a modem.
Is there a way to connect the USB to the unused ethernet port ?
Old 28-06-2008, 9:30 PM   #5 (permalink)
Johnnie's Avatar
Thanks: Gave 11, Got 38
What about this:
http://jkontherun.blogs.com/jkonther...3g-window.html
Would this remove the connection speed limitation?
PSN ID: j0hnn1ewalker
Johnnie is offline
Old 29-06-2008, 8:41 AM   #6 (permalink)
If he was on a wnw handset option (£7.50) then his speed may have been capped at the server end.
Sy1441 is offline
Old 29-06-2008, 1:24 PM   #7 (permalink)
Johnnie's Avatar
Surely using wmwifirouter would not have the same limitations as it would just create an ad-hoc wireless network on your phone.
So your laptop/pc would connect at the maximum speed possible, which obviously depends on your phones connection speed as wireless b or g would be faster than even the best current HSDPA connection.
I'm actually considering getting an EeePC which will fit in my rucksack ( I cycle to work! ) and using this method on my Orbit 2 so I can have a really portable computer and can connect to the web almost anywhere!
I was looking at all the various models of smartphones and pocket PC's but then realised that browsing the web on any of the current devices would be seriously compromised by a small screen etc and not that much better than on my Orbit 2, so I'm planning on getting a cheap/free upgrade phone from T-Mobile which I can sell to pay for the EeePC
Johnnie is offline
Old 29-06-2008, 5:57 PM   #8 (permalink)
Thanks: Gave 1, Got 10
I have been doing the EEE pc and a tmobile HSDPA connection via my LG for a 6 months and it works great. The EEE is a terific bit of kit for the money, i got the original 7inch version for about £220 last december stuck on XP and havent looked back since.
Connection speeds are great the only thing is its not quite quick enough for iplayer but you can use sopcast and other streaming sites
supersub40 is offline
Johnnie (29-06-2008)
Old 29-06-2008, 9:17 PM   #9 (permalink)
Johnnie's Avatar
That's good to know!
I was tempted by the new slightly larger models of eeepc, but the cost nearer £400 and are obviously slightly more bulky, so I think I'm just going to get this:
http://www.expansys.com/p.aspx?i=158607
Can you just put an SD card in to the slot on the side? does it go all the way in or does it 'stick out'?
Also do you know what the max capacity card that can be installed?
Sorry, didn't mean to hijack this thread
Johnnie is offline
Old 30-06-2008, 12:14 PM   #10 (permalink)
kingdannyb's Avatar
What about this:
Unfortunately not seeing as the W890 doesn't have wi-fi !
Having had no help from either Sony or T-Mobile I may have to go back to T-Mobile and ask for a replacement phone (probaly the n95) seeing as they are advertising something that doesn't work.
Old 02-07-2008, 1:01 PM   #11 (permalink)
kingdannyb's Avatar
. . . . however, I have found an option in settings/connectivity/streaming settings/connect using/local connections called . . . USB Ethernet !
I'm going to have a play with it tonight and update the thread with the results.
Old 02-07-2008, 8:20 PM   #12 (permalink)
Johnnie's Avatar
I have used a usb to ethernet adaptor on a PC before, I was having problems with the on board NIC and had to use it to allow me to connect to the net to download drivers.
Good Luck!
Johnnie is offline
hsdpa, modem, w890
Refbacks are On
Thread Thread Starter Forum Replies Last Post
HSDPA modem setting Help sonic_fan82 Networking 6 10-07-2008 5:29 PM
O2 3G and HSDPA Con! dpadmore Mobile Phones and PDAs 18 10-05-2008 9:43 PM
modem surfing speeds always slow when raining ? are these modem signals ok ? trapster Virgin Media Blueyonder 0 03-02-2008 11:16 PM
Hsdpa Jewperman Networking 6 16-12-2007 12:36 AM
Wanted : Cheap ADSL Modem / Wired modem router monkeynuts Archive : Completed Business and Expired Threads 14 07-02-2007 5:51 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
