AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 24-06-2008, 2:56 PM   #1 (permalink)
How do i remove all the 3 branding from my n95 8gb ?
i got it unlocked because i wanted to use my t-mobile contract in it but i hate!! 3 so could somone point me in the right direction how to remove it all maybe flashing it with somthing or other i dunno ? thanks in advance !!
sfxhewitt is offline
Old 24-06-2008, 7:31 PM   #2 (permalink)
Thanks: Gave 58, Got 74
Re: How do i remove all the 3 branding from my n95 8gb ?
Search google and download Nemesis Service Suite and follow the instructions. Once finished you can install nokia software updater and upgrade to the latest firmware. (the following instructions were taken from another site).
1) Install NSS onto your computer. The latest versions work with both Windows XP and Windows Vista.
2) Connect your N95 to your computer, via USB, in PC Suite mode.
3) Launch NSS.
4) Click on the magnifying glass in the top right of the NSS window. This should then detect your phone and bring up it's info.
5) When your phone has been found, click on the Phone Info button and wait for it to read more info from your phone.
6) Now click on the Read button on the right hand side of the screen. You will see the phone's product code, H/W code, manufacturing date and IMEI number displayed.
7) Choose the product code you want to use (remember the codes for the N95 classic are different to the 8Gb). Generally, the EURO1 code should meet most people's needs.
8) Overtype the product code with the one you have chosen from the Product Codes thread (see above)
9) Tick the Enable box and then press Write
Your product code has now been changed. You can quit NSS and now open Nokia Software updater to update your phone in the normal manner.
Have you ever danced with the devil in the pale moonlight?
My A/V setup
Sandman is offline
Old 24-06-2008, 10:32 PM   #3 (permalink)
silent's Avatar
Thanks: Gave 23, Got 9
the updater doesn't work on vista though
David Moyes Blue and White Army
silent is offline
Old 25-06-2008, 9:00 AM   #4 (permalink)
I know, it is annoying isn't it. Cant be that hard to find someone with an xp machine you can use though.
My A/V setup
Sandman is offline
Old 25-06-2008, 9:10 PM   #5 (permalink)
silent's Avatar
i have acquired system commander and will install XP on a partition.
my project for tonight, eek!
silent is offline
Old 26-06-2008, 3:41 PM   #6 (permalink)
Thanks: Gave 5, Got 6
http://discussions.europe.nokia.com/...cending&page=1
Read through this thread.
Basically just restart NSU after it crashes and it willl complete the update, worked fine on my N95
Kanduru is offline
8gb, branding, n95, remove
Refbacks are On
Thread Thread Starter Forum Replies Last Post
"safely remove hardware" - how to remove a device form this list? Moodie UK Windows XP 2 17-05-2008 10:52 PM
de-branding a SE K610i Autopilot Mobile Phones and PDAs 0 04-10-2007 7:59 PM
Can you get rid of network branding Ash007 Mobile Phones and PDAs 1 10-05-2007 5:22 PM
How do you remove manuf. branding from IE title bar? Bravia PC Games 7 11-02-2007 5:11 PM
K800i Un-branding and re-branding to different network JCoster Mobile Phones and PDAs 8 19-10-2006 8:32 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
