22-06-2008, 5:58 PM
#1 (permalink)
Thanks: Gave 11, Got 0
dvd on pc to n95 8gb
Hi , Dont mean to sound stupid !  but how the hell do you get dvd once converted though Super to my N95 ? please dont laugh......thought i was technically minded , thats just gone straight out the window.
TH42PX60ped, Sony TA-VE215 Amp, Sony DVP-S735D DVD, Panasonic DMR-ES10EB DVD Recorder, Toshiba TDP-S8 projector, Sky HD, SKy +, SKy stnd, PS3, Nintendo Wii, XBOX 360 Elite,and a N95 8gb all wrappd up in a sesame seed bun
22-06-2008, 6:46 PM
#2 (permalink)
Re: dvd on pc to n95 8gb
Dont answer , i have solved it.......but so far only managed to transfer 1 part, I am attemting all 5 vob files , will they all come out as 1 film ?
22-06-2008, 10:05 PM
#3 (permalink)
Thanks: Gave 66, Got 145
you would be much better off converting the DVD to xvid \ avi or even mp4 before transferring to your N95.
23-06-2008, 5:48 PM
#4 (permalink)
cheers, but the problem i have is that i have transfered em to MP4 but before this they are splitting up into different parts rather than 1 whole film.
24-06-2008, 1:04 PM
#5 (permalink)
Thanks: Gave 58, Got 74
Can the N95 play xvid avi files? I have hundreds of them on my pc (all ripped from my own dvd library).
Have you ever danced with the devil in the pale moonlight?
My A/V setup
24-06-2008, 8:56 PM
#6 (permalink)
use something like Coreplayer or many other xvid/avi Symbian based players
24-06-2008, 9:06 PM
#7 (permalink)
Thanks: Gave 33, Got 186
This is because a .vob file on a dvd has a max size of 0.99gb. What program did you use to rip the dvd initially? Using dvdshrink, the movie can be ripped to a single file, using a menu option.
Main Kit: Samsung 37A558 / Sky+ / Sony HTSS1000 / Sony RDR-GX120 / Toshiba HD-E1
Bedroom Kit: Sharp 32X20E 1080p/ Acoustic Solutions DS 534 / Xbox 360 Elite + HD DVD
Laptop: Rock Pegasus 670 - 15.4" WSXGA / C2D 2.2GHz / 8600M GT 512mb / 2GB RAM & 2.5TB HDD
25-06-2008, 8:25 PM
#8 (permalink)
yeh am useing DvdShrink, just noticed settings and wolla worked, cheers for your help.
