| Re: help BT Diverse 6210 fault
I have located the problem. After a lot of plugging and unplugging I found that the Diverse 6210 handsets were working fine.
The problem was caused by the phone answering machine (BT Response 75 circa 2000) which for some reason caused the external line to drop when trying to xfer call on the Diverse handsets.
I do not know the reason why. It is not a problem of REM overload the total REM is below the notional limit. The answering machine has worked with DECT phones quite happily for the last eight years or so.
If anyone has any thoughts I would be grateful. However I will be getting a new compatible answer machine to replace the Response 75.
