| Re: Full Internet phones?
A lot of phones will give you Internet access. These days you have the choice between UIQ (SE), Series 60 (Nokia), Windows Mobile and flash based properitary operating systems such as the one used by the Viewty and G800. I haven't used a browser on S60v3 for a while so I can't comment on that.
Pocket IE (Windows Mobile) is horrible for all but the most basic site or mobile specific sites such as mobile Google. You can install Opera Mini 4 or join the Skyfire beta, which bother offer experiences closer to the desktop variants.
UIQ uses Opera, which is pretty decent. I have only found one or two sites that didn't render properly (e.g. Outlook Mobile Access) but otherwise it gives a decent experience.
Browsing on the Viewty was ok but it was no better than any of the other devices above.
The answer to your other quesitons, Windows Mobile (or Pocket PC as it was known in the days of the original XDA). Microsoft have improved the operating system, especially the stability and memory management. There are also a lot more developers creating new applications compared with the days of Pocket PC 2003.
At the end of the day, most phones offer PIM functionality and Internet access. Best thing to do is going into an Orange or 3 store to see which one you get along with as both provider's stores have the phones on display for you to play with.
