Originally Posted by SCAB i was told that if i turn off the 3G on my k800i, i will increase the battery life significantly
now i have no idea what 3G is, but i've found the option to have GSM and 3g or just GSM
now i'm also unsure what GSM is
can somebody please tell me what 3G is, what GSM is, will i be missing out on anything by turning 3G off? and would you recommend turning 3G off?
thanks in advance |
GSM is what most phones for many years have been. 3G has been around for about 7 years and is simply a new way that phones and networks talk to each other.
The main difference between GSM (2G) and 3G is that 3G allows higher data speeds if you are using your phone for data (e.g. internet browsing etc.). If you are not doing that, then 3G will not offer you many advantages. If you are doing that, you may notice a difference in speed.
