Originally Posted by ant_j BTW is there a way of finding out the product code, ie make sure i changed it back? |
The easiest way to check the Product Code in the phone is to use Nemesis Service Suite (NSS) and just Read the code. Check it's the same as the one on the label on the back under the battery.
It's very unlikely that a Nokia Service Centre will care about the firmware Variant or Product Code. O2 might, but shouldn't for a mechanical fault unless they want to exchange yours with a refurb unit; in this case thay won't like having a unit with upgraded firmware to refurb for someone else.
Have you tried doing a full phone format (*#7370#) without the memory card in just to make sure it is a hardware fault?
Don't forget that this will wipe everything on your phone.
