MSN you can get through 3 by joining them. Not sure who the developer is
Alternatively, there is
this solution, or
this (visit this one using your phone), or
this. Can't say I have used any of them. I just did a google search.
On my Treo, I use Fring which should be available for the K800 but I find it's user interface a little clumsy.
As for email, it depends on which email provider you are trying to access. Yahoo and GMail both should give you the option to download their dedicated java clients
UPDATE: Official MSN client
http://www.clubsonyericsson.com/en/0...ony-ericssons/
