Originally Posted by insomniak123 Just noticed some more details about WebNWalk -
they say with the standard webnwalk that it doesn't count for "downloads" (isn't everything you look at on the net 'downloaded' ?  )
Also say you can't use your phone as a modem for your PC (thus routing HDSPA through my N95 into my girlfriends home PC which is still for some reason devoid of broadband!)
How could they restrict this? Do they know when my Nokia is connected to my PC? |
As standard for new contacts HSDPA is disabled for the standard web'n'walk.
You get a 1GB fair usage, you're not supposed to use this for connecting to your PC, but in reality there's not much way they could tell (they probably won't say much unless you go over the fair usage). You're not supposed to use instant messengers either, and depending on the ports it uses, they might be able to tell in this case, I'm not sure. Normal internet downloads on your phone (apart from chargable ringtones, backgrounds etc. from the T-Mobile portal) are all included in this allowance.
However, they don't mention that HSDPA is disabled anywhere and generally seem to keep quiet about it - so in my case I rang them up, argued (reasonably and calmly) for a bit, and they phoned me back a bit later offering me an upgrade from web'n'walk to web'n'walk plus for free. This gives you HSDPA, a 3gb fair usage, and they don't care if you connect it to your computer. You connect your phone to the computer and use it as a modem, you don't get the USB thing unless you're on the internet only package.
As a side note, I've found T-Mobile customer service excellent, a lot better than any of the other operators I've been with.
