Found the supposed settings, still having problems though
In case any one needs the settings
To manually setup your phone for E-mail please follow the instructions below.
Manual settings :
01) Press [Menu] and select the [Settings] tab.
02) Select [Phone settings] > [Connectivity] > [Access points].
03) In [Access points] press [Add].
04) Enter the following information :
Connection title : Orange WAP GPRS
Bearer : GPRS
Authentication : PAP
Username : (none)
Password : (none)
APN : orangewap
05) Press [Save].
06) Press the end call key to return to the main screen.
07) Press [Menu] and select the first tab.
08) Select [Messaging] > [Settings] > [email] > [Email accounts].
09) Press to the left icon to see the options.
10) Select [Add new].
11) Enter the following information :
Title : Orange.net
My name : Sender name
User name : Login for POP3 email access (none)
Password : Password for POP3 email access (none)
Email address : Your email address
Reply email address : Your email address
Outgoing mail server : 193.252.23.5
Incoming mail server : 193.252.23.1 (none)
Maximum receive size : 400 KB
Mailbox type : POP3
Save to server : On
(Only IMAP4) Save sent mail into : Handset
Access point : Select the new access point Orange WAP GPRS
Auto retieve : User's choice
Advanced settings : On
SMTP port number : 25
Incoming port number : 110 (none)
SMTP authentication : (none)
SMTP Username : (none)
SMTP Password : (none)
(Only POP3) APOP secure login : Off
12) Press [Save].
13) Select the new email account Orange.net and press [Activate].
The new profile is saved and activated.
