22-11-2007, 8:59 PM
#1 (permalink)
Thanks: Gave 32, Got 104
LG Viewty slow USB transfer?
Got this today and its a great phone, just transfering about 550 megs of divx to the card via the supplied usb cable and using the lg pc suite software and its taking ages, looks about 45 mins to complete, i thought this was a usb 2 device? could it be a slow mem card?
Planar PD7060, Sim2 Tab Tensioned Electric Screen, Panasonic 42PV500, Sony STRDG820 Amp, Jamo A102s 5.1, Samsung BD-P1400 Bluray, Sky HD, Xbox 360 + HDDVD, Nintendo Wii, Octava HDMI switch/DA, Quad Core PC, Dell 2407 24" Monitor.
22-11-2007, 9:20 PM
#2 (permalink)
Thanks: Gave 2, Got 3
Re: LG Viewty slow USB transfer?
No idea as Lg suite on my laptop only allows me to sync my phone, if i try to transfer anything using the tools i get an error message so i have to take out my memory card and plug it into my laptop and then copy it across that way
22-11-2007, 9:27 PM
#3 (permalink)
Thanks: Gave 19, Got 38
You get faster transfer speed if you change the phone setting .Menu>Cog?? menu>Phone Settings>Connectivity>USB connection Mode and change it to Mass Storage. You cant use the PC Suite .It will just show up as a removable disk in My Computer.
PSN ID - LionOfTheSouthUK
Xbox 360 Gamertag - LionOfTheSouth
22-11-2007, 9:39 PM
#4 (permalink)
many thanks for that, i hate using pc suites, much prefer normal storage drag and drop without all the crap, nice one
22-11-2007, 9:58 PM
#5 (permalink)
Cheers works a treat
04-05-2008, 2:36 PM
#6 (permalink)
Hello, i have a problem with my USB connection, i can't seem to find a way to get my photo's and video's off my LG viewty to my pc.. I don't have a memory card so the above doesn't work.
