Originally Posted by dafinity
Hello All,
New owner of 1.1.2 unlocked iPhone, and now forced to use iTunes to get my music on the phone.
Issue is, only a few covers were found for my full, tagged albums.
iTunes says I must create an account to 'get album artwork' from iStore.
Is this going to cost me to join or download my covers? it does ask for credit card details to join.
Is there any worry about iTunes or the Store messing with my hundreds of albums with their protection (i think its called DRM)
Finally - many of my full albums have been messed up by iTunes for example albums have been split up and each single track appears as its own album - is there any way to merge these single tracks back into their album?
Many thanks for help and advice,
Russ
You can delete the credit card details from an ITMS account once you have opened it, and it doesn't cost anything to download album art.
ITMS cannot apply DRM to your existing files - it won't touch them. It only applies DRM to tracks you purchase from the Store itsellf.
Make sure that all your ID3 tags are clean - that each file only has either a 1.1 or a 1.2 tag, not both, and make sure that the Album field is exactly the same for each track in an album. You can use iTunes own Get Info command to check this.
