AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 21-11-2007, 10:44 PM   #1 (permalink)
Thanks: Gave 70, Got 57
Please Help ! Retrieving Numbers From A Broken Mobile Phone
i smashed the screen on my mobile phone the other day, the phone still actually works with incoming calls, nevertheless i'm getting a new phone tomorrow,my problem is i had a lot of numbers on there i would like to retrieve if at all possible(on the phone not the sim card)therefore is there anything i can do to get them from the old phone onto my PC and then transfer them to the new phone, the phone i broke was the sony ericsson W750i and the new one will be the k800i, so over to you guys for any help and suggestions, many thanks in advance
beachy is offline
Old 21-11-2007, 10:55 PM   #2 (permalink)
gra123's Avatar
Thanks: Gave 85, Got 83
Re: Please Help ! Retrieving Numbers From A Broken Mobile Phone
can't you hook it up to your computer and then use sony ericsson Pc suite to browse the contacts on the phone.
link to Pc suite
http://www.sonyericsson.com/cws/supp...0i?cc=gb&lc=en
gra123 is offline
Old 22-11-2007, 1:33 AM   #3 (permalink)
I had the same problem with my K750i, screen smashed as forklift truck drove over it. I bought a new screen off the internet, can't remember the site, but it's easy to find, just type into google, spare screen w850i or something. If you're not frightened to take the thing apart, it's not actually that hard to replace the screen. There are instructions for that, with pictures, again on the internet. Just do a search. Otherwise, if it won't connect through PC suite, you could borrow a friend's phone, just copy the button presses, in contacts there is an option to "send all contacts", just select that and then via bluetooth, and you can send all your contacts just like that to your new phone. That's what I did.
hayamburuk is offline
broken, mobile, numbers, phone, retrieving
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Help contract phone broken can we get a PayG phone to replace it? Anim Mobile Phones and PDAs 8 30-06-2007 8:45 AM
Broken Sony Ericsson Phone on T-Mobile. Help needed! Henry Mobile Phones and PDAs 3 26-08-2006 11:50 AM
cant phone 12 didgit numbers bcham Mobile Phones and PDAs 9 25-08-2006 9:40 AM
Mobile Phone broken after 6 months - what do you do? Paul O General Chat 6 30-08-2005 7:51 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
