dvd decrypter , save the dvd as a vob file. PS3 video 9 (
www.redkawa.com) and add the nokia profiles:-
http://www.n95users.com/forum/third-...onversion.html
Be careful cos if you overwrite the ps3.xml file that comes with the latest version of PS3 video 9 you'll lose some of the latest profiles like MKV passthrough, what I did was cut and paste all the nokia profiles from the ps3.xml file in the zip file into the one in the PS3 Video 9 directory. I use 256kbps small which works fine but you could use a higher bitrate if you wanted to. Basically just click on the convert tab and then current conversion then convert video, select the .vob file and the nokia profile you want to use and click on start. That will output a .mp4 file that you can transfer to your memory card (in \My Videos folder). That's a very quick version cos I'm doing it during half time, if you need more details I'll be happy to oblige later
Andy
