20-11-2007, 9:22 AM
#1 (permalink)
Thanks: Gave 141, Got 30
Blackberry or iphone?
I've been asked by work to get a Blackberry for email purposes, but I know that the new iphones have a full querty email function too. Has anyone used both and is one better or more user friendly than the other please? Thanks in advance for anyone's opinion  .
"Of course, it's time for Woody's RoundUp. He's the very best! He's the rootinest, tootinest cowboy in the wild, wild west!"
20-11-2007, 9:40 AM
#2 (permalink)
Thanks: Gave 322, Got 133
Re: Blackberry or iphone?
depends who your email provider is, if you have your own in house one you will be better off with an enterprise server and blackberry. i-phone could be diffiicult...
Xbox 360 Tag - Original Moo ------- PSN Tag - Original-Moo
20-11-2007, 9:40 AM
#3 (permalink)
Thanks: Gave 37, Got 174
You'd have to ask if work would support an iPhone. POP3 and mobile web is superb, I have a friend with a BlackBerry and he's now looking at the iPhone.
w: www.randomphotos.net
#: Canon 1D Mk III - Bunch of Lenses. Bag full of other stuff :#
20-11-2007, 11:41 AM
#4 (permalink)
Thanks: Gave 67, Got 84
Iphone also supports IMAP which syncs with all your email folders etc... its a bit meaty really.
You should have posted this in the mobile section...... would have got more answers.
My Web Folio flickr - Photography
Nikon D200 + battery Mount, Nikon AF-S 17-55mm f/2.8G IF-ED DX, Metz 58 AF1, Powerbook G4 + Mac Pro Harpertown, 2 X Leica R6 + Array of Lenses
20-11-2007, 11:44 AM
#5 (permalink)
You got that working then? Can't figure mine out, although the Leopard mail client won't connect either so guessing it's some incompatability.
20-11-2007, 12:20 PM
#6 (permalink)
Thanks: Gave 110, Got 31
To be fair, I woiuld have thought that if work want you to have a device for email purposes then they should be providing you with one?
Life is a matter of luck, and the odds in favour of success are in no way enhanced by extreme caution.
20-11-2007, 12:27 PM
#7 (permalink)
Thanks: Gave 33, Got 66
remember iPhone has no 3G(if you were thinking of using it)
Toshiba 42X3030D LCD , VAIO VGN-AR11S(Blu-Ray) Laptop,Humax FOXSAT
Q6600 , 8800Ultra SLI , Raptor X, G15 , TripleHead2Go
Turbo Hayabusa(430bhp ) EVE ONLINE: BIMJO YARRR
20-11-2007, 1:35 PM
#8 (permalink)
Thanks: Gave 153, Got 330
Works perfectly for my iPhone and my Macbook, IMAP makes it so much easier to keep it all in sync and not having to review the read emails again etc...
Neither have many of the blackberry's, really not necessary for email...
JP
20-11-2007, 1:57 PM
#9 (permalink)
Yeah would be a great help but fails on the auth when I know it's right, ah well as long as I know it works I'll speak to my sysadmin
20-11-2007, 2:00 PM
#10 (permalink)
I'm working on them - they say Blackberry, I say iPhone  .
20-11-2007, 6:30 PM
#11 (permalink)
Thanks: Gave 85, Got 533
If Corporate push email is the intended primary use then i'm sorry but a Blackberry or Windows Mobile device is probably the best solution. (Depending on what's running on your exchange server)
If your just talking IMAP or POP3 email access then you can probably just use an iphone as easily.
PSN - Uridium_UK
20-11-2007, 6:40 PM
#12 (permalink)
Thanks: Gave 117, Got 64
Do remember that the iphone is not yet available to corporate users so the subscription would have to be a personal one and the company would have to reimburse you. Could be a bit too much of a faff for them.
Just take it as read that I spend too much on gadgets and gizmos
20-11-2007, 8:12 PM
#13 (permalink)
Thanks: Gave 34, Got 21
Blackberry, if you want it for email.
I have an iPhone and a Nokia E61, which is like a Blackberry, and for sheer ease of typing, accuracy and speed, you can't beat a real keyboard.
The iPhone virtual keyboard is good but it will get annoying after a while.
20-11-2007, 8:32 PM
#14 (permalink)
Hmm guess this one is down to personal preference. I've got a Blackberry as well with the dual keys on it, and after a week the iphone is definitely much quicker to type than the Blackberry, and the correction is ten times better. And I like it how the 'landing-zone' gets adapted depending on the word. I don't have big hands but the keys on a blackberry are very small....
Don't know about the Nokia E61 keys, but since symbian is unuseably slow compared to both blackberry and iphone I don't think the limitation is the keyboard, more the rest of the operating system...
JP
20-11-2007, 8:40 PM
#15 (permalink)
Thanks: Gave 364, Got 900
I have a Blackberry and I just couldn't imagine using anything for email. It's form factor is superb and just works very well. The thought of using a touch screen interface (like the iPhone) for email fills me with dread!
