AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 20-11-2007, 8:05 AM   #1 (permalink)
Thanks: Gave 52, Got 70
What wifi provider for non contract Iphone?
I currently have The Cloud £3.99 offer on my Touch which i was hoping to transfer to my non contract O2 Iphone however it seems you cant do that - so what other service providers are there and who offers the best coverage / price?
Or is the O2 £7.50 bolt on for edge sufficient?
zz101 is offline
Old 20-11-2007, 10:25 AM   #2 (permalink)
Thanks: Gave 123, Got 223
Re: What wifi provider for non contract Iphone?
Another member has managed to use his iphone Cloud account to connect his Mac. Can't you just connect your iphone using the same credentials you use on the Touch?
The usefulness of the O2 bolt on would depend very much on the Edge coverage where you need to use it. it only covers around 305 of the UK population at present.
All that is necessary for the triumph of evil is that good men do nothing. attributed to Edmund Burke.
Philips 37PF9830, Denon AVR4306, Humax HDCI-2000T, Panasonic NV-HD660B, Philips N1700, Xbox360, Technics SP25, Sony CDP-CX450, Sony CDP-CX455, SkyHD, Nokia N95 8GB
andykn is offline
Old 20-11-2007, 10:57 AM   #3 (permalink)
Thanks: Gave 153, Got 330
Yes it does not seem to check the MAC address, but...I was using the O2 contract as a roaming partner so I don't know whether that works differently compared to getting an account from the Cloud direct...
JP
dejongj is offline
Old 20-11-2007, 11:00 AM   #4 (permalink)
The Touch uses MAC id only for connecting - theres no login details.
I might try e-mailing them to see if they will just swap MAC id's although the Touch's use different ranges so they might not do it.
zz101 is offline
Old 20-11-2007, 1:29 PM   #5 (permalink)
Is there any way of changing/spoofing the MAC address on the iphone? Although you'd really need to do it on the Touch as well
andykn is offline
contract, iphone, provider, wifi
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Using contract sim with unlocked iphone wens Mobile Phones and PDAs 2 17-11-2007 8:10 AM
Iphone - Mid Contract Ian_Kent Mobile Phones and PDAs 8 21-10-2007 11:54 PM
Contract/ Provider problems Accolade Mobile Phones and PDAs 4 25-07-2007 7:40 AM
Freetalkj contract up - need advice on next provider & set up RSK21 VoIP Internet Telephony 3 01-09-2006 7:33 PM
Which wifi provider? the_sanguine Mobile Phones and PDAs 0 26-02-2006 5:36 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
