AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 26-10-2007, 3:47 PM   #1 (permalink)
Thanks: Gave 8, Got 4
can i use a 3 contract sim in an unlocked phone?
have a 3 contract but have the chance to buy an n73 unlocked, will my 3 contract sim work in it? thx
um4rio is offline
Old 28-10-2007, 11:59 AM   #2 (permalink)
Re: can i use a 3 contract sim in an unlocked phone?
...anyone?
um4rio is offline
Old 28-10-2007, 2:26 PM   #3 (permalink)
Welsh Thunderca's Avatar
Thanks: Gave 7, Got 7
Mmmmmmmmmmmmm I have a 3 sim card in my toshiba g900 portege. But every phone shop says no you cant do it. Sorry for the unhelplessness.
Welsh Thunderca is offline
Old 28-10-2007, 5:21 PM   #4 (permalink)
so do u think its worth the risk? I have a z610i on three contract, and want to use the sim on a black unlocked n73 - what do you think
um4rio is offline
Old 29-10-2007, 11:15 PM   #5 (permalink)
Thanks: Gave 17, Got 38
Don't hold me to this, but as far as i am aware, as long as the phone you put the sim into is 3G, and you don't limit the phone to only 2G networks, you will be fine using a 3 USIM in a non 3 phone. It's only when you put the 3 USIM into a 2G phone, or limit the 3G phone to 2G that they find out you're using a non 3 phone (because you're making calls all the time on the 2G network in an area that should have 3G signal) and in a lot of cases have deactivated the USIM/account.
It's basically because 3 don't have their own 2G network and have to pay o2 (and i think also now Orange are in on this) to use theirs when their own 3G network fails/has no signal.
"It was about that time...."
SeaneyC is offline
Old 31-10-2007, 1:50 PM   #6 (permalink)
hmm thanks.. can anybody second that?
um4rio is offline
Old 31-10-2007, 4:18 PM   #7 (permalink)
james_uk9's Avatar
Thanks: Gave 15, Got 32
Yup its true!
Hitachi 42PD7A10 - Hitachi PJ-TX300 - Sapphire 92" 16:9 Screen - HTPC - V+ - Xbox 360 - Yamaha AX759SE Amp - Harmony 885 - Kef Q7 - MS905i - Kef Q1 - Tannoy TS12 - Evoke 3 - Pocketdab 1500 - Nokia N95. My opinions are just that, and may not represent those of AV Forums.
james_uk9 is offline
contract, phone, sim, unlocked
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
