AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 24-10-2007, 6:07 PM   #1 (permalink)
XDA Orbit - Are they all unlocked?
Quick question - someone is offering me an o2 xda orbit but does not know if its locked to o2 - I heard that they are all unlocked but can someone confirm this?
thanks
froggy128 is offline
Old 24-10-2007, 6:09 PM   #2 (permalink)
Autopilot's Avatar
Thanks: Gave 164, Got 287
Re: XDA Orbit - Are they all unlocked?
Generally yes, XDA's are locked to O2 (unlike normal O2 phones).
Get confirmation before buying, but they are fairly easy to unlock though by yourself.
First Child = Ex Moderator!!!
My opinions expressed here are my own and do not necessarily represent those of the AV Forums or associated websites.
Autopilot is offline
Old 24-10-2007, 8:25 PM   #3 (permalink)
Ayub's Avatar
Thanks: Gave 184, Got 176
Hi, orbits are unlocked UNLIKE MDA 3 COMPACT they are locked to t mobile and are NOT THE SAME as orbits. They use a cheap internal chassis and can be unlocked but cost around £20 at the moment and then sometimes goes wrong ( the flash reboots and keep boothing the phone up and thats all).
I know i went off track but wanted to to make sure you bought the right one. Apprt from that the orbit is good the gps takes a lil while to get your location ( internal) but is very good.
This is my advice and my opinion only.
Ayub is offline
Old 26-10-2007, 5:34 PM   #4 (permalink)
I have an Orbit that is NOT unlocked, or indeed is only partially unlocked in that it will send text messages but cannot phone out or receive calls. Autopilot says that it is easy to unlock , but HOW?
Thanks for any help
Helen Ellis is offline
Old 26-10-2007, 10:01 PM   #5 (permalink)
mr_bo
Posts: n/a
Hi, my 02 Orbit is defo unlocked. HTH
orbit, unlocked, xda
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
