AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 23-10-2007, 1:11 PM   #1 (permalink)
Thanks: Gave 0, Got 6
Old sim with new phone = same number and contacts?
I'm looking to buy a new phone, but for simplicity sake i'd really like to use the same phone number (and have the same contacts, though I could always just write down all the numbers and put em into the new phone so that's not too important).
I'm just wondering if I take my old sim card out and use it with the new phone, does that mean I still use my old telephone number?
Mike45450 is offline
Old 23-10-2007, 1:28 PM   #2 (permalink)
SeedyR's Avatar
Thanks: Gave 216, Got 271
Re: Old sim with new phone = same number and contacts?
Yeah telephone number is all to do with the sim card, so that will mean you have the same number in your new phone. Just be wary that many phones are locked to a network, so say if your sim card is current on Orange, you will have to get a phone which is capable of having an Orange sim in.
If your numbers are store on the sim card, when you put it in your new phone, then they will be with you. However if your numbers are stored in the phone, then yes you will have to find a way to transfer them. The slowest way, as you've already mentioned is to write them down. To save time you may be able to bluetooth them from your own phone to your new one. One year i remember I copied over 90 contacts from my old phone to my sim, then put my sim into my new phone, and copied the contacts from the sim to the new phone. Erased the contacts from the sim, and started the process again until all my contacts had been moved across. It's always a good idea to have a backup of your contacts, as if I ever lost my phone, I'd be more annoyed at all the numbers I've lost than the actual phone itself.
I came to the AV Forums for helpful advice & to hopefully save some money. Now I have a lousy bank balance & the constant urge to upgrade
Consoles: 360 Elite, Wii, PS3 (UK 60gb), PSP & DS Lite
Other things: Sanyo Z3, Onkyo 805, Topfield 5800, Harmony 885, MacBook Pro & 16gb iPhone 3G
SeedyR is offline
Old 23-10-2007, 2:06 PM   #3 (permalink)
Thanks: Gave 6, Got 7
On a lot of phones you can copy the phone numbers from the phone to the sim card & vice-versa
JohnWB is offline
contacts, number, phone, sim
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
