Originally Posted by Welsh Thunderca If you like texting then have a look at these types of phones.HTC Kaiser or even the the Toshiba G900.Ok they are a bit salty and a little on the larger size but they do have good size keys/key boards. |
I don't anticipate texting much. It's probably contributed more to poor grammar and spelling than any other event in history.
Only when necessary and I'll be spelling 'you' and not 'u'.
The problem is that many people can't separate text speak from normal e-mail which drives me up the wall.
Rant off. Thanks for the advice but I've already bought the W810i which is not half as bad as I'd anticipated given the size of the keypad. Your tips will hopefully help others.
