Originally Posted by ma1234 They would probably unlock it in a similar or the same way iphonesimfree unlocking works ie not affected by a software upgrade, they only have to approve the activation then. |
Now that's an interesting point. When some of the iPhone dev team were looking at the original unlocking, they looked at reverse engineering the IPSF unlock. Now.. according to Giz the IPSF unlock (when you have unbricked your iPhone by reverting back to 1.0.2 from 1.1.1) will work after re-activating using whichever method (Ibrickr or independance).
So, how long until this becomes free again.
But the point is you are having to drop down a firmware to be able to re-unlock your phone from brick status, which in turn erases all your apps.
I dont think Apple would have a leg to stand on if they did that to a fully paid up iPhone.
