Originally Posted by deedee71 hello,
i bought my samsung u600 yesterday, but i dunno how to make pictures full screen size when scrolling through them.
also, how do i take a good video as picture is grainy, and small, and then it says message full or something? how can i take a clear big video and also a video that's longer than a few seconds?  |
The Video Recorder is MMS setting by default. Thats why its so small and that you can only record a limited time
Here's step-by-step to get higher video resolution:
1. Go to the camera
2. Press '1' to go to Video Record mode.
3. Press the left touch-key to enter settings
4. Go to 'Recording Mode' (7th icon from the left)
5. Select 'For full memory'
You should now be able to record video with an resolution of 352x288. Check what resolution you can choose from the 'Size' menu.
