Originally Posted by chris777uk Hi all?
i have a xda mini s and have followed instructions to set up my gmail account with my phone, it connects to GPRS but has an error and says content cannot be downloaded check connection or something like that.
Anyone any wise words?
Chris |
I'm not 100% sure about all the networks but you should be able to connect to GPRS to go on the internet or push your emails through to your handset,, the only thing I would say is be careful you don't pay through the nose to get it,
T-Mobile cap it to £1 per day ( stand corrected if it's more ) if you are not on a web n walk contract however some of the other CSP's charge you everytime you connect via GPRS,, I have my phone checking every 30mins for new mail so that would cost me an arm and a leg if I was not on Web n Walk,
Also here is the Gmail settings I used for my Nokia and should work for every phone,
Incoming email:
incoming mail serv: pop.googlemail.com
mailbox type: POP3
Security(ports): SSL/TLS
Port: 995
APOP secure login: off
Outgoing email:
Outgoing mail serv: smtp.googlemail.com
Security (ports): StartTLS
Port: 25
Hope the above helps,
Brian.
