| Re: TomTom Nav 6.
Touch the screen for the menu, scroll right with the ">" button until you see "Clear Route" and hit that.
If you cant find that option, it probably because you need to go into preferences and select 'show all options'. TomTom can be run in a 'simple' mode with some of the menu options hidden to make use simpler for some people. God only know why they think that option needs to be hidden.
And yes, its handy running it without a route so you can just use it as a speed camera locator.
