travelling to South Korea and Japan
Old 13-02-2007, 2:25 AM   #1
NoBob
Posts: n/a
My first post's about mobile phones that can be bought in the UK and which will work in S Korea and Japan. Would anyone happen to know from experience which make/models do?
Thanks,
NoBob.
Old 13-02-2007, 7:34 AM   #2
4,602, Level: 16
Points: 4,602, Level: 16 Points: 4,602, Level: 16 Points: 4,602, Level: 16
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 14, Got 134
Re: travelling to South Korea and Japan
Never seen a S. Korea compatible phone for sale in the UK (that's not so say there aren't any) but you can hire one.
http://www.abroad.vodafone.co.uk/ind...e=a3&nu=1&le=3
Old 13-02-2007, 4:41 PM   #3
NoBob
Posts: n/a
Thanks.
I followed that link and found a couple:
There's the Skyphone and
Japan - Panasonic J-P02
Korea - IM-5200
NoBob.
Old 01-03-2007, 2:23 PM   #4
3,600, Level: 14
Points: 3,600, Level: 14 Points: 3,600, Level: 14 Points: 3,600, Level: 14
Went to S.Korea a couple of months back and found that I needed a Quadband phone. I had a SE K750i with me at the time, which didn't provide the required coverage. I think the same is for Japan.
Don't worry though as you can hire phones at Seoul airport for a very reasonable daily rate. This is what I did, the bonus is that the SIM card can be transferred into this new phone and you can still be contactable on your existing number.
Old 01-03-2007, 2:29 PM   #5
siany's Avatar
4,269, Level: 15
Points: 4,269, Level: 15 Points: 4,269, Level: 15 Points: 4,269, Level: 15
Thanks: Gave 2, Got 19
I think you'll just need to find an unlocked Quadband phone, they can be used pretty much anywhere in the world.
Old 01-03-2007, 4:15 PM   #6
Ludicrous69
Posts: n/a
Someone correct me if im wrong but as far as I know the only place you will be able to find a mobile that will work in Japan is, Japan, although I think CPW hire handsets that work in Japan but as far as i know Japans mobile networks are lightyears ahead of GSM, in fact there networks arent even GSM so your standard tri/quad band fone will not work at all
No idea about S. Korea, I was supposed to go there last year but had to can cel at the last minute
Old 01-03-2007, 7:43 PM   #7
6,343, Level: 18
Points: 6,343, Level: 18 Points: 6,343, Level: 18 Points: 6,343, Level: 18
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 107, Got 62
Quadband phones wont work in Japan or Korea, unless it has WCDMA.
The only phones that I am ware of that will work there is the phone I am using (nokia e61) and the phone I used to have Vario 2.
Old 02-03-2007, 12:43 AM   #8
Ludicrous69
Posts: n/a
Is the N95 WCDMA? or whatever it is?
Old 02-03-2007, 11:08 AM   #9
siany's Avatar
4,269, Level: 15
The N95 is an HSDPA (3.5G) device, so it can be about 10 times faster than WCMDA (3G)
Old 02-03-2007, 11:13 AM   #10
Ludicrous69
Posts: n/a
I guess what I was asking is would the N95 work in Japan?
http://cpw.adamphones.com/phonehire/Japan.aspx
"The cutting edge Sharp V302SH operates on Japan's unique PDC 1.5 GHz networks, which have no common standards with the rest of the world."
Old 04-03-2007, 3:33 PM   #11
2,779, Level: 12
Points: 2,779, Level: 12 Points: 2,779, Level: 12 Points: 2,779, Level: 12
Thanks: Gave 1, Got 2
Japan used to be a complete no-go area for our mobiles (they used PDC instead of GSM and CDMA instead of UMTS), but now UMTS is supported so any 3G phone should work over there provided your operator has a roaming agreement in place. The frequency they use is 2100MHz which is the same as Europe's 3G frequency. Look here for more: http://www.gsmworld.com/roaming/gsminfo/index.shtml
Old 08-03-2008, 3:50 PM   #12
4,333, Level: 15
Points: 4,333, Level: 15 Points: 4,333, Level: 15 Points: 4,333, Level: 15
Thanks: Gave 0, Got 3
It is a similar story for South Korea. Although a quadband phone which supports CDMA is best, there is also 3G UMTS coverage in major cities.
A UK 3G phone should work as long as your operator has a roaming agreement set up. It is unlikely to be cheap ...
I must admit that although I could make/receive calls and receive texts, I could not send any texts. I didn't spend much time trying to figure it out.
Old 06-01-2009, 12:18 PM   #13
Darwin70
Posts: n/a
You will need a quad band phone for Japan. You could choose to rent either the SIM or the SIM and handset from Cellhire (International mobile phones & Mobile Broadband deals - Cellhire). They sort everything out for you and provide you with a local SIM that gives you much cheaper call rates.
The Japanese SIM is here Japan SIM card rental - Cellhire
The South Korea SIM is here Korea mobile phone rental - Cellhire
In both cases incoming calls are free and they'll deliver it to your door.
Old 12-01-2009, 9:31 PM   #14
GreenBars's Avatar
4,464, Level: 15
Points: 4,464, Level: 15 Points: 4,464, Level: 15 Points: 4,464, Level: 15
Thanks: Gave 24, Got 25
I'm off to Japan to stay with the wife's family at Easter. I've been researching the best way of using my mobile on Japan and think Story Telecom's TravelTalk SIM card is the cheapest.
Just noticed they're out of stock - buggar!
Last edited by GreenBars; 24-02-2009 at 1:21 PM. Reason: Added comment about stock
Old 15-01-2009, 10:03 PM   #15
GreenBars's Avatar
4,464, Level: 15
Now back in stock and have ordered one.
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
4 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 13th at 2:30pm. Prices include delivery.
