Orange SPV M600
Old 16-12-2006, 4:13 PM   #1
3,701, Level: 14
Points: 3,701, Level: 14 Points: 3,701, Level: 14 Points: 3,701, Level: 14
Thanks: Gave 186, Got 34
Orange SPV M600
I was hoping one of you kind people can help me out with my new Orange SPV M600, I appear to be having problems with the length of time the phone rings for when an incoming call is received! may sound a basic problem but i cant seem to get it to ring for more than 3-5 seconds, certainly not always long enough for you to get the phone out of your pocket and answer it.
I cant seem to find anywhere in the menus that will change the length of time it rings for before it stops and shows that I have a missed call. It does it regardless of whether its on ring only or vibrate and ring?
Any assistance would be greatly appreciated.
7up4it
Old 16-12-2006, 8:12 PM   #2
5,952, Level: 18
Points: 5,952, Level: 18 Points: 5,952, Level: 18 Points: 5,952, Level: 18
Thanks: Gave 33, Got 32
Re: Orange SPV M600
isnt this a voicemail setting? divert to voicemail after x number of rings?
7up4it (18-12-2006)
Old 18-12-2006, 9:41 AM   #3
3,701, Level: 14
Re: Orange SPV M600
I called into my local Orange shop for assistance (not exactly over helpful to be honest!) the assistant informed me that it was not a problem with the phone settings as such but a code number had to be entered to prevent this from happenning. He told me I had to ring 150 for the code, turns out as its a company phone you have to ring 158, they were extremely helpful and gave me a 15 digit code that I had to enter into the phone which has solved the problem
Overall I am very impressed with the phone/PDA and would highly recommend it, although i'm no expert
Old 18-12-2006, 9:59 AM   #4
Daddy k's Avatar
14,121, Level: 28
Points: 14,121, Level: 28 Points: 14,121, Level: 28 Points: 14,121, Level: 28
Activity: 14.9%
Activity: 14.9% Activity: 14.9% Activity: 14.9%
Thanks: Gave 374, Got 286
Re: Orange SPV M600
also to further adjust the settings,
goto:
phonepad (press the call key is the quickest way)
menu in lower right
options:
highlight call forwarding
click get settings
then adjust the settings shown on new screen
7up4it (18-12-2006)
Old 18-12-2006, 4:19 PM   #5
3,701, Level: 14
Re: Orange SPV M600
It's not very often that your'e wrong Daddy K and you're right again!
Old 18-12-2006, 4:29 PM   #6
Daddy k's Avatar
14,121, Level: 28
Activity: 14.9%
Re: Orange SPV M600
i keep telling me mrs that but she has none of it
love these devices but they could often be a little easier to work at times, especially the phone side.
Old 19-12-2006, 5:16 PM   #7
4,092, Level: 15
Points: 4,092, Level: 15 Points: 4,092, Level: 15 Points: 4,092, Level: 15
Thanks: Gave 4, Got 17
Re: Orange SPV M600
If anyone else comes across this problem, try this Start, settings, then phone icon, when the phone icon has been pressed you will get a box open with Phone,services, network etc along the bottom of the screen goto the furthest which is called more and see what setting you have on the Automatic pickup because if this is ticked the phone will answer incoming calls without pressing talk within 3 rings.
Have just purchased microsoft voice command for my m600 and well impressed, theres a free 5 day trial on handango web site, the windows mobile 3 version does work on this phone, although they do have a american version for windows 5 that allows you to use the programme with a blue tooth headset ( just remember though that they pronounce mobile and other words differently ) which is why i purchased the older version, i can basically start any programme on my phone by using my voice, will admit that i have had a few hiccups but it usually works fine and saves messing about with the stylus especially when you can just press one button that you assighn the programme and then just say call mark at home, 9 out of 10 from me although my Mrs reckons the voice on the programme sounds chinese
Old 19-12-2006, 10:37 PM   #8
Daddy k's Avatar
14,121, Level: 28
Activity: 14.9%
Re: Orange SPV M600
dont forget a goodparty trick is when u get ms voice command to read out your texts to you too
Old 23-12-2006, 11:05 PM   #9
4,092, Level: 15
Re: Orange SPV M600
Daddyk how do you do that, good little programme but didnt know it can do that
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
3 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 12th at 2:30pm. Prices include delivery.
