N80 v4 firmware update for Orange & 3 available on NSU
Old 21-10-2006, 6:14 PM   #1
cracker's Avatar
8,887, Level: 22
Points: 8,887, Level: 22 Points: 8,887, Level: 22 Points: 8,887, Level: 22
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 22, Got 269
The Nokia Software Updater application will now update Orange and 3 network N80's to v4 firmware
There may be updates for O2/Voda/T-Mobile too but i cant say for sure as i dont have an N80 on those networks to test out
I've just successfully updated my Orange N80 from v3 to
V 4.0623.0.41
26-07-2006
RM-92
Nokia N80 (31.04)
So while its not the VERY latest release (.42) its still better than V3!
I will also see if FOTA has been activated and if i can get .42 via that
AT LAST!!
Old 22-10-2006, 9:23 AM   #2
3,296, Level: 13
Points: 3,296, Level: 13 Points: 3,296, Level: 13 Points: 3,296, Level: 13
Thanks: Gave 13, Got 12
Re: N80 v4 firmware update for Orange & 3 available on NSU
I just tried to do an update on my Voda N80 and it said nothing is avaliable.
Old 22-10-2006, 9:55 AM   #3
11,438, Level: 25
Points: 11,438, Level: 25 Points: 11,438, Level: 25 Points: 11,438, Level: 25
Thanks: Gave 129, Got 50
Cracker, maybe you can help. I've just tried the updater on my phone (Orange N80) and it does say a new update is available. Unfortunately, after downloading the update it asks me to insert to "Nokia USB Installation Disk" which I don't have. Where do I get that from?
Old 22-10-2006, 11:20 AM   #4
cracker's Avatar
8,887, Level: 22
Activity: 2.4%
Doh! Looks like it's just for Orange/3 users at the moment then
ParmMann did you have the Nokia PC Suite (not NSU) installed on your system before you tried the update? (I.e the software you use to backup your phone contacts etc)
The only thing i can think of is that the PC Suite software contains the usb cable connection drivers, and maybe the NSU app needs those in order to communicate with the phone
If you havent got PC Suite, you can download it from the Nokia website
Old 22-10-2006, 11:39 AM   #5
11,438, Level: 25
Cracker, I figured it out. I just had to browse to the install directory on my C drive and it found the required stuff.
I've updated my phone but unfortunately it's now using the Orange firmware again as opposed to the generic firmare I had before, doh! Oh well, at least it's up to date.
V4.0623.0.41 is the one I have now, haven't noticed what's new yet but at least it is new.
Old 22-10-2006, 11:51 AM   #6
cracker's Avatar
8,887, Level: 22
Activity: 2.4%
Yes i had considered doing a phoenix flash to generic v4, but after i almost managed to mess up my guinea-pig 6280, i decided it might be best to stick to official updates only for my N80
Also, if there is a problem with phone Orange cant blame it on me installing generic firmware
The main differences ive seen are the Orange Music Player and OrangeTV apps, as well as the Nokia Search, and antivirus
Phone seems to run a lot faster now, also the boot-up time has halved! My 2gb mem card now works a lot better too. Also the text-messaging font is now bold, which doesnt make any difference to me, but a lot of people thought the old font was too small to read
Old 23-10-2006, 9:18 AM   #7
11,438, Level: 25
I must admit, I've not had a problem with the new firmware yet, Orange or not. I've now noticed a few of the extra apps, haven't used them yet but the Photography, TV and anti virus are all there.
Old 23-10-2006, 9:20 AM   #8
cracker's Avatar
8,887, Level: 22
Activity: 2.4%
another small thing which im glad this v4 firmware has fixed is that annoying automatic re-connection to GPRS every time you reboot the phone!
Old 23-10-2006, 9:22 AM   #9
11,438, Level: 25
Is it possible to remove some of the Orange apps? Particularly the Photography one, there seems to be shortcuts for it everywhere and it's one app that I'm certainly not likely to use.
Old 23-10-2006, 10:25 AM   #10
cracker's Avatar
8,887, Level: 22
Activity: 2.4%
I've not removed the Orange Photo app, but if you go into it, accept the agreement (if its the first time you go in), then go into options -> settings -> and scroll down and select "disbale photography service" and say yes to the warning
This will totally disable the service, so it wont keep asking you to "send to friend" etc every time you take a picture
If there were other features of it that you did want to use, you can turn off individual things like the camera prompt etc in that settings menu
Old 23-10-2006, 10:28 AM   #11
11,438, Level: 25
Thanks for the tip, I've done that and I'll just remove all it's shortcuts manually.
Old 27-10-2006, 9:06 AM   #12
2,220, Level: 10
Points: 2,220, Level: 10 Points: 2,220, Level: 10 Points: 2,220, Level: 10
Thanks: Gave 17, Got 6
Any ideas when new firmware for o2 handsets will be released?
Old 05-11-2006, 10:06 AM   #13
4,476, Level: 15
Points: 4,476, Level: 15 Points: 4,476, Level: 15 Points: 4,476, Level: 15
[QUOTE=cracker;3641028]
V 4.0623.0.41
26-07-2006
RM-92
Nokia N80 (31.04)
QUOTE]
how do you see which firmware your running in the phones settings?
i updated mine yesterday through Nokia Updater
thanks
Old 05-11-2006, 10:27 AM   #14
cracker's Avatar
8,887, Level: 22
Activity: 2.4%
*#0000#
Old 05-11-2006, 2:15 PM   #15
7,462, Level: 20
Points: 7,462, Level: 20 Points: 7,462, Level: 20 Points: 7,462, Level: 20
Thanks: Gave 4, Got 5
Can someone provide a direct link to the V4 firmware for the N80 on the 3 network ?
cheers
Old 05-11-2006, 2:18 PM   #16
cracker's Avatar
8,887, Level: 22
Activity: 2.4%
not via NSU
and "home flashing" requires illegal Nokia service software, so cant be discussed here
Old 06-11-2006, 10:06 AM   #17
4,476, Level: 15
Originally Posted by cracker View Post
*#0000#
thx man
im running below - phone is still a little slow though
V 4.0623.0.41
26-07-2006
RM-92
Nokia N80 (31.04)
i hear on some forums that V5 firmware has just been released or was released end October anyone got it?
ive also been informed that a Kinston 1GB mini sd card makes this phone run faster??
:UPDATE: - Kingston 1GB card now in my phone and it has made it run slightly quicker.
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
3 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £295.99 Click to show/hide the offers
Sony Ericsson Xperia arc S
3 prices from
 £294.99 Click to show/hide the offers
 Updated February 11th at 10:30am. Prices include delivery.
