I just got a new mobile, a Motorola L6 locked to O2.
My old mobile is a Nokia 6680 locked to 3.
My original plan was to use my USB dongle to sync my PC the 6680, copy the information across to whatever PC software Motorola uses, then sync that to the L6.
The trouble is, my bluetooth dongle doesn't want to co-operate. Whenever I plug it in I get USB device not recognised error despite having installed the latest Bluesoleil software.
Then I thought I would just send the data directly via bluetooth between the phones. The Motorola made me manually accept all 370 contacts (!!) but then when that was finished, they weren't in my contacts! It seemed to have sent them but not stored them
I have though of using USB to connect the phones to my PC, but I can't find the cable for the 6680 and I didn't get one with the L6.
I've just thought, I have an old SE T68i lying around that is unlocked. If I can work out how to copy the contacts info in the phone onto the SIM (I think the SIM can only store 250 entries, not sure how I'll get around that), copy them from the SIM into the T68i memory, put the the O2 SIM, and then copy them from the phone onto that. Will that work?
Thanks for any help, I really don't fancy manually putting in 370 entires
