Well Thats not going to work
I go into ActiveSync, tap menu, and have the following options:
Options
Status
Add server source
Connections
Connect via IR
Connect Via BlueTooth.
If I go into OPTIONS, I get: Choose the data you want to sync, and a list of "Contacts, calender, e-mail etc"....and this is available for both "WorcPC" and "Windows PC <HOME>)
STATUS, I get a "Last syncronised Date:time" Work PC
"Last syncronised Date:time" HomePC
ADD SERVER SOURCE:
serveraddress:<BLANK> and
"This server requires an encrypted (SSL) Connection is ticked. (Should it be?, I'm assuming it makes no diference)
CONNECTIONS:
when cradles, sychronised all PCs using this connection: USB
Does that help eliminate anything?
Thanks for your on-going help!!
