| Networking Help - N80
Hi, im trying to network my N80 to my LAN, to get on the internet.
heres my current setup.
BT Router > PC
> Laptop
and obviously, the pc and laptop use the router as a gateway to the internet. simple! this original setup is wired with 100mbps lan cards.
i would like the following:
BT Router > PC
> Laptop >> N80
> = Wired
>> = Wifi
now, i can connect the n80 to the laptop, but i cant get on to the internet
at the moment the IPs are thus
192.168.0.1 > 192.168.0.2
> 192.168.0.3/192.168.0.4 >> 192.168.0.5
basically, the 100mbps lan card in the laptop is .3, and the wifi is .4, and the N80 is .5.
is there something i can do different to get the internet connection available on the N80?
one way would be to change the laptop to 192.168.0.1 but then the router has to change to something which then stops the laptop being able to access the net.
Help!
