Originally Posted by Smurfin I could go to £300. Why keep them separate? With 2 mobiles, an iPod sat nav and an iPaq, my suit pockets are going to be bursting on days when I'm out of the office lol |
I just prefer to keep mine separate. Sat/nav stays in the car, pda stays on me. If your pda packs up (a multitude of things can go wrong, running out of memory, too many applications, etc. which can all affect the gps side of things). But each to their own, I suppose. As regards, pda/satnav bundles there are loads out there. Spec for the pda aspect does not need to be too extravagent if all you are after is basic PIM funcionalty, and the TomTom Nav 5 is one of the best GPS add-ons.
If you go for pda/satnav bundle make sure that you can charge both the receiver and the pda from the one cigarette lighter charger lead.
This looks reasonable ...
http://www.globalpositioningsystems....ff59ebea30d2cd
or Palm with Michelin...
http://www.totalpda.co.uk/Palm-TE2-w...companion.aspx
